Actor Animation - Shuffle Issue
Hey,
The shuffle sequences in "Actor Animation", doesnt seem to work on me, I tried clearing the cache.
3ds max 2019
TyFlow: v0,16014
Will need more info...can you post your file or send it to support@tyflow.com.
I got help from TyFlow, The fix was.
 In order for shuffling to work, your operator timing has to be set to "Continuous", so that it continually updates particles. Currently, it's set to "entry" so that particles are only updated by it once. If you set to continuous, you'll see the sequence shuffling happens.
