Vray Override Mtl Doesn't Affect TyFlow
It appears that the Vray Material Override (in render global switches) doesn't affect TyFlow geometry for some reason. I've tried both rendering as triangle mesh and Vray instances.  Same thing happens if I render a tyCache object instead.  I've also tested both include and exclude lists for the override mtl with no success. Using Max 2019, Vray Next 1.2, TyFlow 16018.
Hmm that's odd. One thing you can try is rendering in mesh mode and disabling the VRay Interface in the tyFlow interfaces rollout. I will make a note to look into it as well.
Thanks Tyson. Disabling the VRay Interface under the Interfaces rollout seems to fix the override issue.
The override issue was also fixed in the latest version.
(05-08-2019, 11:17 PM)tyFlow Wrote: The override issue was also fixed in the latest version.
Excellent!
