05-06-2019, 09:34 AM
HI!Tyson
"Custom Properties" - save object map color channel
"Object Bind" - Bind Position_Limits_Limit offset can read the object map color, and can determine the offset height according to the color change. Can be set to animation.
"Speed" can increase the way the object normal is read. The speed value can be controlled according to the color of the object map.
"Surface Force"-Normals_ can control the intensity through the object map color
