Rotation (surface Align) - to fast rotation.
Hey,
I'm doing little crowd sim and everything goes quite well but for the rotation of the agents.
I use particle physics (collide) to avoid actors intersections.
The problem appears when the agents change the direction rapidly.
The Rotation operator (surface align - forward vector from velocity)  changes their rotation alignment in just 2-3 frames.
I need a much slower rotation. I tried a "slow " and "limit" operators for spin. None of them seems to be able to slow down  Rotation speed for the agents. Any thoughts?
Thank You,
Best
Chris
Reduce the interpolation setting in the Rotation operator. Try 0.1.
(05-06-2019, 02:39 PM)tyFlow Wrote: Reduce the interpolation setting in the Rotation operator. Try 0.1.
Checking now.
Thanks, Tyson Smile
Best
It works quite well.
Checking now.
Thanks, Tyson Smile
Best
I Would be great to have spin limit also Smile
Sure, I can add an interpolation setting to the Spin operator.
