Voronoi Fracture——Position offset
HI, I am using particle breakage. It was found that the broken position was deviated from the particles. I have repeatedly created a lot of such scenarios. There is still such a deviation. Is there a problem with this? Thank you
That's odd...thank you for bringing it to my attention. Can you upload the scene or send to support@tyflow.com? Thanks.
This is the scene file. for max2017
There is another problem. When I created two TYFLOWs, I found that they always confused me because I couldn't distinguish them. If this is a project, I have to create a lot of TFLOW icons. At this time, I hope to be able to distinguish them by "custom name" or other methods.
I will allow users to change the wirecolor of tyFlow icons in the next build.
Also in the main tyFlow settings you can see there is a display name option which allows you to display the tyFlow's name in the viewport. However, right now it overlaps the logo inside the circle so it's a bit hard to read. I will fix that as well in the next build.
I'll also fix the voronoi issue too. Thanks!
Thank you for your great contribution, Tyson
