BetterWind Modifier
Would be possible to add support for BetterWind Modifier? (http://www.rpmanager.com/plugins/BetterWind.htm)
Currently i can pick with the Force operator but seems dont work.
(05-09-2019, 01:44 PM)wejm Wrote: Hi,
right now, you have to use very high values for turbulence to see the effect
Yep.  Same is true with Max's Motion Fields.  You have to use some crazy high values.
Pretty much that, yea...at some point I have to figure out why certain max spacewarps need such a huge influence boost to work. My guess is that their velocities are normalized per ticks rather than per second....not sure, but for now just crank up the influence values.
