Problem with Corona Render
It seems that it's not possible to render with Corona.
When I try to render the scene, with IR or Render an error message appear :
"You have 3ds Max bitmap paging enabled. This is known to drastically reduce performance of textures while rendering"
I disable paging, restart 3ds, but 3ds still freezing when I try rendered an exemple scene
I use 3ds Max 2018
Hmm...that's odd....tyFlow doesn't make any modification to the bitmap paging system, however I also haven't tested with Octane renderer at all. Maybe something else is causing that problem and the bitmap paging error is coming up instead. I'll look into it, thanks!
Thanks to you, and for this awsome tool Wink
Can confirm, as soon as i hit render with any sort of tyflow in the scene, 3ds max freezes and crashes.
3ds max 2018
Corona 3 stable
Could you try putting an edit mesh on top of the tyFlow and hitting render? That will basically bypass the interfaces that tyFlow exposes and might be a temporary workaround.
it's not working for me, same error message and 3ds freezing and crashe
Same for me, still crashes.
Initial tests: 3ds Max 2020 - Corona 4 latest daily
1) tyFlow freeze/crash
2) Added edit mesh/edit poly modifier - renders ok
3) Turned on DOF - render ok
4) Turned on motion blur - crash
5) Turned off motion blur - render ok
6) Started interactive render - freeze
*bitmap paging has nothing to do with crashing*
(04-01-2019, 07:54 PM)SoniKalien Wrote: Initial tests: 3ds Max 2020 - Corona 4 latest daily
Where exactly did you add the Edit Mesh/Poly Modifier?
(04-01-2019, 07:56 PM)Heerockss Wrote: Where exactly did you add the Edit Mesh/Poly Modifier?
On top of the tyflow object - for example in the tyflow_cloth_001 scene, I selected the emitted cloths, and then applied the edit mesh modifier on top.
Awesome, thank you, that really did the trick Smile
it's seems it work here too, but still have the Corona warning
Update :
Works with Render, but still freezing with IR
IPR freeze max when tyflow object in the scene , on vray next, max 2020, windows 7, tyflow version 016006.
i see corona IPR freeze too...
any news on that ?
Thanks !
