Corona motion blur
I have a simple flow filling up a container, problem is I get an error in corona that it cant do geometry motion blur with changing topology. How can I get motion blur on the "Shape, 3D" geometry?
Thanks!
Corona isn't an officially supported renderer. Unfortunately your only option is to setup your flow in a way that ensures particle count doesn't change over time. One way of doing this is instead of birthing/deleting particles, just scale them to 0 when you don't want to see them.
(06-07-2019, 03:46 PM)tyFlow Wrote: Corona isn't an officially supported renderer. Unfortunately your only option is to setup your flow in a way that ensures particle count doesn't change over time. One way of doing this is instead of birthing/deleting particles, just scale them to 0 when you don't want to see them.
I also have Vray 3. Would the issues still apply?
With VRay you can switch the Mesh operator to instance mode, so it should render moblur correctly.
Is there any plan to support corona in the future?
Not currently.
