Add a data channel to the "Scale" node
HI,Tyson!
I hope to add a data channel to the "Scale" node. The size of the particles is influenced by the data. For example, the particle's "Distance, Position, Rotation, Angle, Velocity, Material ID, Object Map Color" affects the scaling value of the particle.
I think this can do a lot of very creative results.
Thank you
I wonder if it makes more sense to simply add more controls to the Custom Properties operator, so you can choose to add, multiply, divide, etc custom data to whichever channel you assign it to.
That way the custom property could not only easily control scale like that, but any other assignable property...
