Voronoi internal geometry / cap issues
Some polygons go missing when using the Voronoi Fracture operator. I've tested this with different shapes, using "cloud" or "random on shape surface" options, and with or without "optimize slice borders" turned on.
The attached max file shows this issue, and you should be able to see it with or without "optimize slice borders" on from the set camera location at frame 0. Tyflow 0.16043 and Max 2020.
You forgot the file Smile
Ah, my bad. I selected the file but didn't hit "Add Attachment".
.max   Voronoi-cap-issue.max (Size: 652 KB / Downloads: 5)
Thanks, I'll make a note to check the scene when I get the chance.
In the meantime, make sure your geometry doesn't have self intersections and things like that....they can cause problems when fracturing.
I've checked the scene file and confirmed the issue. I'll put a fix on the todo list Smile
Thumbs Up
(08-15-2019, 02:37 AM)tyFlow Wrote: I've checked the scene file and confirmed the issue. I'll put a fix on the todo list Smile
Thanks, Tyson! You're the best Big Grin
