Layers of simulation precached - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Layers of simulation precached (/thread-1023.html) |
Layers of simulation precached - nineworld - 08-18-2019 Hi. When I worked on a destruction I had 5 levels of fractures and different conditions. And I had to wait every time to simulate the whole stack of events when I wanted to adjust or tweak the last event. My question is if there is some sort of work flow where I would simulate and cache events in layers as they go down so I would have those final layers precached and then I would tweak and simulate the last event (layer) on top and it would be faster because it would have to calculate just this last event. RE: Layers of simulation precached - tyFlow - 08-18-2019 That's what Birth Flow and Flow Update are for. Import a cached flow into another and the cached flow won't recache when the second flow is updated. Layers can go as deep as you need. RE: Layers of simulation precached - nineworld - 08-18-2019 Hmmm I seee. Thanks I will try it. Another question Is there something like a custom switcher I would put my chosen values into so I don't have to go through all the menus and events and I would have 5 final values exposed while I'm tweaking it in my viewport. Like wiring values for a rig. RE: Layers of simulation precached - tyFlow - 08-20-2019 Not currently, no. |
