ty cache f.offset use speed % - Printable Version
+--- Thread: ty cache f.offset use speed % (/thread-1034.html)
ty cache f.offset use speed % - houou - 08-20-2019
maybe i'm wrong.
Just in noticed frame offset works afected by the speed% a bit below.
so if i set frame offset at 2500, will really be delayed until frame 5000 if the speed is set up at 50%.
mmm wouldn't it be better not related there? but then again, maybe I'm missing something.
and adding, how about a "loop", "hold" kind of buttons there?
now can be done "by Frame" and doing it by hand, but just as a fast click would be convenient.
Thankyou.
RE: ty cache f.offset use speed % - tyFlow - 08-20-2019
Frame offset is applied after retime calculations, but you have to make sure you also set the proper ref frame value too.
