Affecting texture of inner faces of pieces of an object broken with voronoi operator - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Affecting texture of inner faces of pieces of an object broken with voronoi operator (/thread-1099.html) |
Affecting texture of inner faces of pieces of an object broken with voronoi operator - Kentonia - 09-08-2019 Hi, Is there a way to affect the inner faces of broken pieces of a voronoi object after destruction? I believe rayfire has something called the asperity modifier that helps to do this? Could it be affected by UV mapping possibly? Then one can use bump maps to achieve same result. Cheers RE: Affecting texture of inner faces of pieces of an object broken with voronoi operator - tyFlow - 09-09-2019 Yes, and there is an example in the example files. RE: Affecting texture of inner faces of pieces of an object broken with voronoi operator - Kentonia - 09-09-2019 Oh ok, just looked at it now. Did not see that one before. My bad. Thanks Tyson. |
