Render selected - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Render selected (/thread-1143.html) |
Render selected - richard21 - 09-24-2019 Hi! I have an issue when I try to use "render selected" mask and highlight the tyflow particles. Thay doesn't rendering. Screenshot RE: Render selected - TMiller - 09-25-2020 Same here. What's weird is that when I select a tyFlow object as a mask, it masks something else that was not selected (a ForestPack object, in my case). Don't know if this helps figuring out what's causing the issue. RE: Render selected - biglittlepictures - 11-12-2020 Same, I seriously need this too.
RE: Render selected - tyFlow - 11-15-2020 Which renderer? RE: Render selected - Alpha Opacity - 05-27-2022 (11-15-2020, 09:08 PM)tyFlow Wrote: Which renderer?Hi there, I have the same issue with a scene. with "Vray 5.20 and 5.20.03 " and "Max2021" "Tyflow version 1.004" It just wont render, also tried TyCache, same result. Hopefully the info can help to resolve this. if more needed im happy to supply. Thnx Tyson, Mike RE: Render selected - tyFlow - 05-30-2022 What won't render? RE: Render selected - Alpha Opacity - 05-31-2022 (05-30-2022, 02:44 AM)tyFlow Wrote: What won't render? A "render mask" in vray.. Selection or a layer. Selecting a tyflow won't render. (05-31-2022, 04:33 PM)Alpha Opacity Wrote:I can send a file if you want.. stripped down.(05-30-2022, 02:44 AM)tyFlow Wrote: What won't render? RE: Render selected - tyFlow - 06-01-2022 Well tyFlow just hands VRay raw data and doesn't actually do anything itself during the post-setup portion of a render. If something specific like that isn't coming through, your best bet would be to contact Chaos Group. In my experience they're pretty quick to respond to queries on their forum. RE: Render selected - Alpha Opacity - 06-01-2022 (06-01-2022, 01:55 PM)tyFlow Wrote: Well tyFlow just hands VRay raw data and doesn't actually do anything itself during the post-setup portion of a render. If something specific like that isn't coming through, your best bet would be to contact Chaos Group. In my experience they're pretty quick to respond to queries on their forum. Thnx Tyson, Will do that, and report back for others who encounter this problem. Cheers Mike |
