tyFlow v0.16054 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16054 (BETA) (/thread-1214.html) |
tyFlow v0.16054 (BETA) - tyFlow - 10-20-2019 tyFlow v0.16054 is up! http://beta.tyflow.com Additions: * changing a float value controlled with a tyRateOfChange controller will automatically adjust the controller's offset value accordingly * added new per-particle break mode to PhysX Break and Particle Break operators Fixes: * fixed a regression that could cause particles to stop moving when Particle Physics is used and OpenCL is enabled, if no cloth or particle bind constraints exist * fixed an issue where pivot point adjustments to a mesh using as a skinned tyActor could result in broken skinning within the flow, requiring a resetXForm operation. * fixed a bug where the Move Pivots operator was not displaying the right info in the operator name * fixed a bug where choosing various local export options from the viewport menu would still attempt a network export * implemented a measure which should prevent a tySelect from being able to choose a tyFlow which is referencing the object the tySelect is on (creates an infinite evaluation loop) * fixed a bug that could crash the Script operator if an invalid map channel was referenced with the GetClosestUVW function * fixed a bug causing certain "GetClosestX" Script operator functions to crash, when called in multithreaded mode RE: tyFlow v0.16054 (BETA) - Borzacch - 10-20-2019 Thanks! redshift instances, pleeeaseeeeeeee! =) |
