the "tySplineMesher" itself axial. - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: the "tySplineMesher" itself axial. (/thread-1273.html) |
the "tySplineMesher" itself axial. - cgdvs - 11-12-2019 How to modify the "axis" of the "tySplineMesher" object. I tried to use "Travel direction" but it didn't work. In this scenario, there is a wrong choice for "tySelect" in a frame. RE: the "tySplineMesher" itself axial. - tyFlow - 11-12-2019 Did you increase the "accuracy" setting in the tySelect Mesh params? Not sure what you mean by the tySplineMesher axis... RE: the "tySplineMesher" itself axial. - cgdvs - 11-13-2019 I want to align the object to the surface normal and follow my own speed direction RE: the "tySplineMesher" itself axial. - tyFlow - 11-13-2019 Just align your particles to the surface/velocity however you like, then in the tySplineMesher settings choose knots as the orientation source. RE: the "tySplineMesher" itself axial. - cgdvs - 11-13-2019 Thank you for your answer, it has been solved perfectly. |
