TySelect Assign to Vertex Colors Refresh Issues - Printable Version
+--- Thread: TySelect Assign to Vertex Colors Refresh Issues (/thread-1404.html)
TySelect Assign to Vertex Colors Refresh Issues - mitchfx - 01-28-2020
We've been finding some inconsistent results using the "Assign to Vertex Colors" option in TySelect.  It will often not refresh correctly until you click on the TySelect modifier in the again then back to top of stack.  This happens on certain objects and not others, even in the same scene.  I'm digging into finding some repeatable steps but so far it's been elusive.
RE: TySelect Assign to Vertex Colors Refresh Issues - tyFlow - 01-29-2020
Looks like an issue caused by setting the vertex color destination channel to something other than zero. Will be fixed in the next build, in the meantime just put a UVW XForm modifier under your tySelects and set some keyframes on a random setting, so that it invalidates the internal texmap cache each frame.
RE: TySelect Assign to Vertex Colors Refresh Issues - mitchfx - 01-30-2020
(01-29-2020, 03:46 AM)tyFlow Wrote: Looks like an issue caused by setting the vertex color destination channel to something other than zero. Will be fixed in the next build, in the meantime just put a UVW XForm modifier under your tySelects and set some keyframes on a random setting, so that it invalidates the internal texmap cache each frame.
Thanks Tyson!
