tyFlow v0.16071 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16071 (BETA) (/thread-1454.html) |
tyFlow v0.16071 (BETA) - tyFlow - 02-15-2020 tyFlow v0.16071 is up! http://beta.tyflow.com Additions: * added tySmooth modifier, for much faster mesh auto-smoothing than max's built-in Smooth modifier * added offset and speed options to operator keyframes rollout * added "at rendertime only" settings to cloth/actor mesh generation * added "max neighbors" setting to Particle Physics operator (see docs for more info) * added MAXScript listener performance warnings to Particle Physics operator * added ability to save current animation frame to a custom float channel in the Shape operator * added "current selection" and "relax" selectors to tySelect modifier Fixes: * fixed an issue where the Subdivide operator would crash if the max Macrorecorder is enabled * fixed a bug that was causing tyParticleSkin to run much slower when "use mesh verts" is enabled, but no particles have mesh vertices * fixed a crash that could occur in the Grow operator if clustering is enabled * fixed an issue where the "real-world value" gravity menus weren't respecting system unit scales (they were assuming 1 unit = 1 inch) * fixed a crash that could while processing a mesh with no faces * fixed a rare bug that could result in NaNs being generated by surface proximity tests (side-effects were things like particles jumping to wrong locations within Object Bind operators) * fixed an issue where a retimed sim that's an input object of another sim wouldn't update properly * fixed an issue where tyConform wouldn't update after landing on a keyframe where the influence amount is 0% |
