volume material id change - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: volume material id change (/thread-1543.html) |
volume material id change - edgar - 03-13-2020 hi. i want to do some effect but there is no any solutions on the web. 1) i have cylinder - verticies grid. its my hidden animated(wave ripple etc) control geometry — «volume1». 2) on this grid i have tyflow particles spread only on verticies(cylinder’s) and constraint to them(object bind — lock to surface) 3) i have hidden cube-brick (animated moving and animated deformations) moves through particles — «volume2» I want my tyflow particles change material id in this moving brick volume2. i attached example in cinema, can anybody do it with tyflow? https://www.youtube.com/watch?v=_r46EMqJ3_4 RE: volume material id change - tyFlow - 03-14-2020 Send the particles back and forth between two events, using a Surface test. One tests for "inside", one tests for "outside". Have a different mat ID in either event. |
