Can I create particles on the surface of geometry generated from particles ? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Can I create particles on the surface of geometry generated from particles ? (/thread-1638.html) |
Can I create particles on the surface of geometry generated from particles ? - batking2 - 04-15-2020 hello Tyfamily ,
I have been trying to create water droplets on the surface of bunch of oranges I generated using Tyflow but no luck , can anyone teach me the right way to do it please ?
Thank you in advance
RE: Can I create particles on the surface of geometry generated from particles ? - TubeSmokeGuy - 04-15-2020 You can use the spawn operator to place and align the spawns onto the parents shape surface. RE: Can I create particles on the surface of geometry generated from particles ? - shadowkiller - 04-15-2020 Can you cache the geometry result first and then feed that back into tyflow? RE: Can I create particles on the surface of geometry generated from particles ? - d4rk3lf - 04-16-2020 There's an easy way actually ![]() Here's the tip: Add "mesh operator" to your "oranges tyflow", and untick "render only". Now you can pick oranges tyflow in second tyflow, just like any other mesh ![]() |
