correct mass property - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: correct mass property (/thread-1976.html) |
correct mass property - Emmanuel - 09-26-2020 Hi I'm looking for the correct mass property By using this tableĀ https://en.wikipedia.org/wiki/Density If wood is 700 i need to put 0.7 or Concrete 2,400 means 2.4 for Mass override? https://youtu.be/ZRCuWV4Dybk RE: correct mass property - d4rk3lf - 09-28-2020 If I understood correctly, mass parameter is only affecting influence from one particle to another. Force on witch the bigger massed particle push particles with smaller mass. It has nothing to do with gravity, or density. But, to be sure, check the doc files. |
