TySelect broken (tyFlow 0.16096) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: TySelect broken (tyFlow 0.16096) (/thread-2069.html) |
TySelect broken (tyFlow 0.16096) - Gregory - 11-23-2020 Hi Tyson, TySelect gives instant crash the moment you try to select something with it. Haven't tested other ty modifiers if they work... Hope you're aware of this. Thanks, Greg RE: TySelect broken (tyFlow 0.16096) - tyFlow - 11-24-2020 Thanks, it's a regression that will be fixed in the next build. In the meantime, put an edit mesh modifier under your tySelect (or just be sure you're not using tySelect on an edit poly object) and it shouldn't happen. |
