Voronoi Fracture - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Voronoi Fracture (/thread-2103.html) |
Voronoi Fracture - peshang - 12-18-2020 When it comes to sourcing Voronoi points What is the difference between the point cloud generated by: Random on Shape surface in Voronoi point type vs Random on shape surface under Point cloud center when using Cloud method? RE: Voronoi Fracture - tyFlow - 12-18-2020 Points on shape surface means the center of each voronoi cell will be located on the shape surface somewhere. Center on shape surface means the center of the voronoi cloud (not the cells themselves) will be located on the shape surface somewhere. Turn on point cloud display to see the difference. RE: Voronoi Fracture - peshang - 12-21-2020 Thank you so much! that explained it. |
