Birth from Point cloud object - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Birth from Point cloud object (/thread-2175.html) |
Birth from Point cloud object - TubeSmokeGuy - 01-25-2021 Hi! It would be cool if we could birth particles or vdb, directly from 3dsmax pointcloud object. https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-49CE0ACB-1345-4D50-B6E5-361DBFDB5B33 What Do you think? Thank you and greetings! RE: Birth from Point cloud object - tyFlow - 01-25-2021 If it exposes the IParticleObjectExt interface, then you should already be able to import it using a Birth Flow/Flow Update operator. If not, you'll have to ask the max devs to support that interface. RE: Birth from Point cloud object - TubeSmokeGuy - 01-26-2021 (01-25-2021, 06:27 PM)tyFlow Wrote: If it exposes the IParticleObjectExt interface, then you should already be able to import it using a Birth Flow/Flow Update operator. If not, you'll have to ask the max devs to support that interface. It's not pickable by Birth Flow / Flow Update. So I assume, that it's not supported. Thank you anyway! :-) RE: Birth from Point cloud object - TubeSmokeGuy - 01-26-2021 Created a request here: https://forums.autodesk.com/t5/3ds-max-ideas/expose-quot-point-cloud-object-quot-to-the-quot/idi-p/10031283 So gogogo for voting! :-) |
