terminating a Simulation - Printable Version
+--- Thread: terminating a Simulation (/thread-2218.html)
terminating a Simulation - caypiranha - 02-14-2021
Hi Guys,
just want it to do no simulation at all after a certain amount of frames, so that the rest of the Animation can stay fast as it was before the Simulation began.
thanks in advance for any Feedback!
RE: terminating a Simulation - tyFlow - 02-14-2021
You can use the retimer to do this. For example, if your timeline goes from frame 0-100 but you only want to ever simulate frame 0-50, you can enable the retimer, set a keyframe on the frame spinner at time 0 with a value of 0, set a keyframe on frame 50 with a value of 50 (remember to set the graph tangents to linear...you can right-click on the spinner and do that from the tyFlow menu at the bottom), and then your sim will only ever simulate that range.
RE: terminating a Simulation - caypiranha - 02-14-2021
thank you very much - working perfect!  =)
I was playing with the Stop Node, but that didn´t work.
I wouldn´t say that the way over the Retimer is an intuitive Idea, but it also isn´t that unlogical too, isn´t it? =)
also saw for the first time the Menue INSIDE the Spinner -  nice one! Haven´t seen it yet and remembers, that there are many hidden features to make live easier
according to that I recognized that the spinners @ "By Speed" Options are not having this feature. That is intentional?
