voxel interaction with birth shape doesnt work - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: voxel interaction with birth shape doesnt work (/thread-226.html) |
voxel interaction with birth shape doesnt work - Tim007 - 04-07-2019 Hi, I have a problem with shape and voxels interaction. I have a simple voxels from teapot and simple shape operator from sphere object. Sphere fall down on voxels and should interact with them, but they are not. When teapot is standard max object, its working, when I edit the teapot and make solid object from it, interaction stop working. video: https://drive.google.com/file/d/1hTRGYBaGrs99-dJlRFphD-hu4t7wEUlg/view?usp=sharing I really dont know, where is problem. Thank you. RE: voxel interaction with birth shape doesnt work - tyFlow - 04-07-2019 Assuming you have a Particle Physics operator on both, if your particles are in separate events you need to uncheck "Process only this event" in your Particle Physics operators. That way particles in different events will talk to each other. RE: voxel interaction with birth shape doesnt work - Tim007 - 04-07-2019 I have that setup but dont know why it doesnt work. ![]() Oh, I have to set Particle Physics as Shape radius, not Scale radius, is that correct? |
