Tyactor modifierstack - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Tyactor modifierstack (/thread-2313.html) |
Tyactor modifierstack - jp3d81 - 03-24-2021 I realized if i use modifiers on top of the skin modifier. Tyactor isn't using all stuff above the skin modifier. Is that right or did i something wrong. In my case i have a skinmorph an editpoly on top of the skin modifier. In tyflow its showing just to the skin. RE: Tyactor modifierstack - tyFlow - 03-24-2021 That is correct....tyActors ignore everything above the skin. If you need other modifiers, either place them under the skin, or place them on the tyFlow itself. If your modifiers are very specific post-skin tweaks to a single actor mesh (ex: edit poly tweaking verts on top of a skin modifiers in the actor's stack) it won't work. RE: Tyactor modifierstack - jp3d81 - 03-25-2021 (03-24-2021, 03:44 PM)tyFlow Wrote: That is correct....tyActors ignore everything above the skin. If you need other modifiers, either place them under the skin, or place them on the tyFlow itself. If your modifiers are very specific post-skin tweaks to a single actor mesh (ex: edit poly tweaking verts on top of a skin modifiers in the actor's stack) it won't work. Alright, got it. Thanks! |
