Can Material change smoothly over frames? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Can Material change smoothly over frames? (/thread-2314.html) |
Can Material change smoothly over frames? - devailo - 03-24-2021 Hi, i am generating some objects which are small and grow in size and they stack up. But what i wanna do is make them white hot glowing when they are born. And the effect would be them appearing white and then cooling off to their normal color/material/ . Now i have a vray material with normal maps and such so can i make it transition from white to my vray material? thanks RE: Can Material change smoothly over frames? - tyFlow - 03-24-2021 If you look at the official example files, you can see how to interpolate through a gradient over time using particle age. That allows you to change particle color over time. RE: Can Material change smoothly over frames? - devailo - 03-24-2021 yes. I've been studying that scene. So i could control a gradient color in my diffuse or self illum map slot inside my material for example? RE: Can Material change smoothly over frames? - drawer14 - 03-24-2021 (03-24-2021, 04:15 PM)devailo Wrote: yes. I've been studying that scene. So i could control a gradient color in my diffuse or self illum map slot inside my material for example? Yeah there is a custom properties tutorial you can find on YouTube that explain what you are asking for RE: Can Material change smoothly over frames? - devailo - 03-25-2021 Yeah, i got it , one important thing i missed was the normalized values in the mapping operator - in the tutorial its 0 - 150 - which meant frames and i missed this , in my case i need less than 10 frames to see the results . So i got it working now ! thanks a bunch, |
