Delete Op Range Values Not Keyable? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Delete Op Range Values Not Keyable? (/thread-237.html) |
Delete Op Range Values Not Keyable? - jrandom - 04-07-2019 I tried to key the Delete operator Range begin/end values, not keyable. Can they be? RE: Delete Op Range Values Not Keyable? - tyFlow - 04-07-2019 Hmm, I see they're not keyable at the moment, but no reason they shouldn't be. I'll make a note. RE: Delete Op Range Values Not Keyable? - jrandom - 04-07-2019 Thanks Not sure exactly how it works, assuming once the value is set to the particle its value would not change, correct? If this were the case a new particle or new entry would acquire the new range according to timing. RE: Delete Op Range Values Not Keyable? - tyFlow - 04-07-2019 It should work fine in theory, particles re-check to see if they're within the valid timing interval each step, so animated timing values would be fine. |
