2 way Cloth interaction - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: 2 way Cloth interaction (/thread-2504.html) |
2 way Cloth interaction - jonnybefree - 07-07-2021 Hi there, Just curios, is it possible to deform cloth with phoenix liquid in 2 way interaction? thanks and best regards Jonas P.S. to be a bit more precise, I have to deform a dense fiber mesh, idealy with fluids wich stick to the cloth and deform it in same time.. RE: 2 way Cloth interaction - tyFlow - 07-07-2021 You'd have to do it using PhysX bodies/binds, rather than typical cloth. It's possible, but probably not worth the hassle. I'd suggest doing your Phoenix sim first, then having your cloth interact with it, then doing a secondary flow for things like drips or whatever you want to have "interact" with the cloth (but it would be a one-way interaction). RE: 2 way Cloth interaction - jonnybefree - 07-08-2021 (07-07-2021, 08:07 PM)tyFlow Wrote: You'd have to do it using PhysX bodies/binds, rather than typical cloth. It's possible, but probably not worth the hassle. I'd suggest doing your Phoenix sim first, then having your cloth interact with it, then doing a secondary flow for things like drips or whatever you want to have "interact" with the cloth (but it would be a one-way interaction). Ja i used spline birth and PhysX binds, and a spline mesher with siblings wich worked quite well too, but when i try'd to Export as alembic it tooked ages for export the spline mesher.. so i switched to cloth. i try to fake a bit using soft bodys now. Thx for your help! |
