Static operator - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Static operator (/thread-2537.html) |
Static operator - cgdvs - 07-23-2021 HI,Tyson! In a large scene, it takes a lot of time to modify a parameter until the whole tyflow is recalculated. For example, a very large volume is broken, and the number of "Voronoi fracture" cuts is 10000, which takes a long time. When I modify the parameters of other operators, can I force the definition of Voronoi fracture to be static (the "Voronoi fracture" operator goes to sleep, even if other operators modify the parameters, it will not be updated). This function is a bit like "auto [one time change]. I don't just refer to the" Voronoi fracture "operator here, but also other operators. thank you RE: Static operator - tyFlow - 07-23-2021 Just do your fracture in another flow and import it with a Birth Flow operator. RE: Static operator - cgdvs - 07-23-2021 Well, OK, this method is really good. thank you If you have the opportunity, I still hope you can consider "static operators". |
