I used the shape operator to read Vray proxy objects and found that UVs were missing. - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: I used the shape operator to read Vray proxy objects and found that UVs were missing. (/thread-2559.html) |
I used the shape operator to read Vray proxy objects and found that UVs were missing. - cgdvs - 08-07-2021 HI,Tyson! I used the shape operator to read Vray proxy objects and found that UVs were missing. thx! Well, I have found a way to add a polygon modifier or polygon selection to the Vray proxy to read the UVs normally. RE: I used the shape operator to read Vray proxy objects and found that UVs were missing. - tyFlow - 08-07-2021 Hmm interesting, which version of VRay/Max are you using? There are differences between them so finding out that info is the first step to solving the issue... RE: I used the shape operator to read Vray proxy objects and found that UVs were missing. - cgdvs - 08-07-2021 3ds max 2021_vray4.3 RE: I used the shape operator to read Vray proxy objects and found that UVs were missing. - tyFlow - 08-07-2021 Can you send the VRay proxy file you're using to support@tyflow.com RE: I used the shape operator to read Vray proxy objects and found that UVs were missing. - cgdvs - 08-08-2021 Sent, thank you |
