The previous simulation becomes the beginning. Without re reading - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: The previous simulation becomes the beginning. Without re reading (/thread-2581.html) |
The previous simulation becomes the beginning. Without re reading - 424454078@qq.com - 08-13-2021 Whether you can add a command to the previous simulation to make it the beginning of the simulation. Instead of exporting particles later. It takes time to read again RE: The previous simulation becomes the beginning. Without re reading - tyFlow - 08-13-2021 You can use a flow's retimer settings to adjust its timing. For example, if you simulate frames 0-500 and want the sim to playback frames 250-500 only, you can set a key in the frame retimer at frame 0 to 250, and then frame 250 to 500, and it will only playback those frames. Be sure you set the frame spinner keyframe interpolation to linear so you don't get ease-in/ease-out on your keys (you can right click it and set its keyframe interpolation from the tyFlow menu). RE: The previous simulation becomes the beginning. Without re reading - 424454078@qq.com - 08-14-2021 Well, thank you |
