The 'weld' operator cannot weld vertices - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: The 'weld' operator cannot weld vertices (/thread-2652.html) |
The 'weld' operator cannot weld vertices - cgdvs - 09-17-2021 HI,Tyson! I got a message from a friend that the "weld" operator cannot weld broken vertices. I've also tested it myself. There is a problem that I can't weld vertices. I'm not sure this friend sent you an email if you didn't receive a similar report. Then I'm a backup here thank you RE: The 'weld' operator cannot weld vertices - tyFlow - 09-18-2021 Hi cgdvs, Could you be more specific about what you mean? For example, I tried just now on a teapot (Birth Objects > Teapot > Weld operator) and the weld completed successfully. RE: The 'weld' operator cannot weld vertices - cgdvs - 09-18-2021 this is test file I'm not sure I have misunderstandings or operational errors. RE: The 'weld' operator cannot weld vertices - tyFlow - 09-18-2021 Ah, I see. The Weld operator only affects the vertices of the shape mesh of a particle. It does not cross-weld shapes together. If you want to attach shapes together and weld their verts, first use an Element Attach operator to convert multiple particles into a single particle, and then you can use the Weld operator to weld those disconnected faces together. RE: The 'weld' operator cannot weld vertices - cgdvs - 09-18-2021 Ha ha, I think the open edges of the mesh can be welded automatically, okay. I see. It seems that I misunderstood. thank you RE: The 'weld' operator cannot weld vertices - usc001 - 02-18-2022 Hey guys, i was facing the same confusion but the forum too good) Just wanted to suggest, to add this information to the documentation site of the weld operator
