neighbour test between flows - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: neighbour test between flows (/thread-2657.html) |
neighbour test between flows - dr_ron69 - 09-22-2021 Hey all title says it all, is it possible to test for neighbours between 2 different flows i have it working in the "same flow", but i would like it between 2. am i missing something simple ta Harv RE: neighbour test between flows - tyFlow - 09-22-2021 Flows can't measure each other directly. If you want to do a neighbor test between them, import the 2nd into the first (or vice versa) using Birth Flow/Flow Update, and then test against those imported particles. RE: neighbour test between flows - dr_ron69 - 09-22-2021 Hey that will probably be more than good enough Thanks Tyson |
