Does it use CPU or GPU - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Does it use CPU or GPU (/thread-276.html) |
Does it use CPU or GPU - dv2000 - 04-08-2019 Hi, does this plugin use CPU or GPU to calculate stuff like softbodies, voronoi, cloth? And if it uses GPU can multiple GPU be used? Thanks RE: Does it use CPU or GPU - anujraghav - 04-08-2019 • Will tyFlow use my GPU? If you have an OpenCL 1.2-compatible GPU with applicable drivers installed, tyFlow will make use of it in its Particle Bind Solver (used to simulate cloth/soft-bodies/grains/etc), as well as the Particle Physics operator (used to calculate inter-particle forces). Currently, no other part of tyFlow’s simulation loop is GPU-accelerated. RE: Does it use CPU or GPU - tyFlow - 04-08-2019 http://docs.tyflow.com/faq/performance/ |
