stop aniamtion - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: stop aniamtion (/thread-2888.html) |
stop aniamtion - dagmara931 - 01-30-2022 Hi, I'm new to tyflow and maybe my question is stupid, but how stop animation on chosen timeline frame, and how set up other animation in same time line after other finish? RE: stop aniamtion - tyFlow - 01-30-2022 Hi Dagmara, That's a pretty broad question, because stopping animation could mean different things...do you just want to stop particles from moving? Or do you want the whole flow to stop/pause? You can use the retiming in frame mode to precisely time how your flow plays back, if you want to simulate a pause effect or something. Or you can use a Stop operator and use the Timing rollout to control when it activates, if you merely want to stop particles by removing their velocity. RE: stop aniamtion - dagmara931 - 01-31-2022 I would like to stop moving the object on sequence number 166 and then (is crate already other animation to she start playing). They both are created in different editors) |
