tYActor PhysX and animation playback multiplier - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: tYActor PhysX and animation playback multiplier (/thread-3026.html) |
tYActor PhysX and animation playback multiplier - chriss3d - 03-26-2022 Hello Guys, I have my school of fish setup based on PhysX , so I don't use tYActor root particles at all, but I want to control animation playback speed multiplier to control my actor animation better. Unfortunately, my velocity is totally messed up because of my root particles and I believe that Actor Animation op reads root particle speed and use it as a multiplier. I'm wondering if there is any workaround ? Thanks Best Chris RE: tYActor PhysX and animation playback multiplier - tyFlow - 03-30-2022 Can you post the file for this issue? RE: tYActor PhysX and animation playback multiplier - chriss3d - 04-01-2022 (03-30-2022, 07:06 PM)tyFlow Wrote: Can you post the file for this issue? Sure. Check attached file. https://drive.google.com/file/d/139mahq2sa2XZEkDgaS9acPKrW4Xc6rZ7/view?usp=sharing Cheers Chris RE: tYActor PhysX and animation playback multiplier - chriss3d - 02-01-2024 (03-30-2022, 07:06 PM)tyFlow Wrote: Can you post the file for this issue? Hello, Were You able to check this file ? Thanks Best |
