Loop/repeat between event - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Loop/repeat between event (/thread-3082.html) |
Loop/repeat between event - Ced J. - 05-11-2022 Hi all ! I need advise with a setup, I have a cloth sim like a flag, it react to wind... (event1) When the flag is inside a mesh, i want it to react differently, so far so good everything works fine, (surfacetest volume inside->event2 different force setting) But when the flag is outside i want that the particle come back to the first behavior we had in event1. How to change the behavior of the particles in 2 directions ? I can do an other event (event 2 surfacetest volume outisde->event3 with same force from event 1 ) but then the flag can't interact multiple time when it's inside this mesh or not. Can you please help me on how to do that ? maybe with group ?? Thanks you ! oh ! I answer my own question, with an other organisation i can finally connect the 2 last event ! All is working now ! |
