Inside object? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Inside object? (/thread-31.html) |
Inside object? - isx - 04-02-2019 is there "inside object"(volume) check like in dataOperator's geometry node? i use this alot to filter particles. i avoid using collision because sometimes it missed when using low substep. thanks i really like TYflow performance!
RE: Inside object? - tyFlow - 04-02-2019 Yep, use a surface test and choose either inside/outside mode. RE: Inside object? - isx - 04-02-2019 (04-02-2019, 08:48 AM)tyFlow Wrote: Yep, use a surface test and choose either inside/outside mode. ah okay...i missed that one, need to dive in deeper... thank you |
