I put the problems I found in this post. - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: I put the problems I found in this post. (/thread-3150.html) |
I put the problems I found in this post. - cgdvs - 06-27-2022 HI,Tyson! Speed in the birth intersections operator has no effect. When the velocity option is turned on and given a value, the particles do not move. Is static. When you drag the select operator here to output to a new event, Max will crash. This problem has been verified on max2022 and max2023. The birth paint operator crashes - cgdvs - 06-27-2022 In the birth paint operator, as shown in the figure, when the point is adjusted to the position in the figure, Max will automatically crash. This problem is verified on max2022 and max2023. RE: I put the problems I found in this post. - tyFlow - 06-27-2022 Thanks! RE: I put the problems I found in this post. - tyFlow - 06-27-2022 I tested the Birth Intersections issue you reported but cannot reproduce it...when I enable the velocity option the particles move as expected... RE: The birth paint operator crashes - nayan - 06-28-2022 (06-27-2022, 04:32 AM)cgdvs Wrote: In the birth paint operator, as shown in the figure, when the point is adjusted to the position in the figure, Max will automatically crash. This problem is verified on max2022 and max2023. Its not crashing in my system....... (06-27-2022, 03:11 AM)cgdvs Wrote: HI,Tyson! Velocity is working as expected in my system..... RE: I put the problems I found in this post. - tyFlow - 06-28-2022 Check the latest build for the crashing and Shape operator fixes! |
