Can you add a "Export Group" setting for "set target" - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Can you add a "Export Group" setting for "set target" (/thread-3171.html) |
Can you add a "Export Group" setting for "set target" - cgdvs - 07-03-2022 HI,Tyson! I want to add "Export Group (ABC...)" to the "set target" operator. I encountered a problem in production: when I use rigid body dynamics, if an event is defined as a "particle group", then rigid body dynamics will "fail". If there is an export group at this time, this problem will be solved. (if you need to add a particle group to each event to balance their relationship because of defining a goal, it will be a waste of time and energy. I hope to solve the goal problem in a simpler way.) Can you add a "Export Group" setting for "set target"? What do you think? thank you RE: Can you add a "Export Group" setting for "set target" - tyFlow - 07-03-2022 Hi, ironically someone else just requested that yesterday (in a DM). Yes I will add that next build ![]() RE: Can you add a "Export Group" setting for "set target" - cgdvs - 07-03-2022 Haha, it's really a coincidence. thank you |
