tyPreview Batch for different Scene States and Frameranges - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: tyPreview Batch for different Scene States and Frameranges (/thread-3184.html) |
tyPreview Batch for different Scene States and Frameranges - hkroeber - 07-15-2022 Hi, when creating Previews most of the time i spend with changing scene states and frame ranges . It would be nice to create a list with this information including frame ranges scene states and offcourse filenames and the rest happens automatically. Regards H.Kroeber RE: tyPreview Batch for different Scene States and Frameranges - TubeSmokeGuy - 07-15-2022 Hi! This is already possible in max with the batch render dialog. Here you can set cameras with frame ranges and scene states. Just browse through it and load your shots and create previews one by one. https://help.autodesk.com/view/3DSMAX/2023/ENU/?guid=GUID-07D3D0DD-3C22-4305-B7FA-01508AB73393 RE: tyPreview Batch for different Scene States and Frameranges - tyFlow - 07-16-2022 tyPreview stores all settings as user attributes of the cameras you are previewing from. For example, if you have cameraA and cameraB, you can assign them different settings within tyPreview and when you switch between them the settings will be retained. That said, if you want the same camera to have different saved settings, that's not possible within tyPreview's capabilities...but you could simply duplicate your camera (perhaps linking it to the first one so that you don't have to sync their transforms manually), then give them unique settings within tyPreview for easy switching between modes. RE: tyPreview Batch for different Scene States and Frameranges - hkroeber - 07-19-2022 (07-15-2022, 02:44 PM)TubeSmokeGuy Wrote: Hi! I know the batch render dialog. But with it it is not possible to create viewport previews. Regards H.Kroeber (07-16-2022, 12:36 PM)tyFlow Wrote: tyPreview stores all settings as user attributes of the cameras you are previewing from. For example, if you have cameraA and cameraB, you can assign them different settings within tyPreview and when you switch between them the settings will be retained. That said, if you want the same camera to have different saved settings, that's not possible within tyPreview's capabilities...but you could simply duplicate your camera (perhaps linking it to the first one so that you don't have to sync their transforms manually), then give them unique settings within tyPreview for easy switching between modes. I use Scene states not because of camera transforms. Most of the time i use it to hide and unhide parts of the scene an blend it together in post. I knew this would be a greater feature but thought i am not the only one who needs it. Regards H.Kroeber RE: tyPreview Batch for different Scene States and Frameranges - Ben Schmücking - 06-22-2025 Hi tyTycoons I do also use scene states to manage, whether objects are hidden or not. Do you know: Is there any possibility to save the information in scene states, whether a particular tyFlow is disabled or enabled? Having multiple tyFlows with a lot to calculate, that would save some time... Best regards, Ben. |
