shaded viewport visibility - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: shaded viewport visibility (/thread-3261.html) |
shaded viewport visibility - tycera - 08-16-2022 Apologies for another basic question, but what could have caused my particles to disappear from a shaded viewport? I think it happened when I pressed ESC during caching. Not sure though. Everything shows fine in wireframe, and everything shows in the shaded viewport of other files. The flow is enabled and there's no transparency in the material. Thanks RE: shaded viewport visibility - tyFlow - 08-17-2022 It's hard to understand what the problem is without screenshots or anything. RE: shaded viewport visibility - tycera - 08-17-2022 (08-17-2022, 05:43 PM)tyFlow Wrote: It's hard to understand what the problem is without screenshots or anything. I have no idea why, but the particles began to show in shaded viewports again. Very sorry to trouble you! RE: shaded viewport visibility - tyFlow - 08-17-2022 No problem, if it happens again just snap a screenshot. Also check that adaptive degradation is not enabled in your view. RE: shaded viewport visibility - tycera - 08-17-2022 (08-17-2022, 05:53 PM)tyFlow Wrote: No problem, if it happens again just snap a screenshot. Will do. Thank you. RE: shaded viewport visibility - Credemon - 08-18-2022 while caching if u press ESC tyflow will not show any mesh or "ticks" in the viewport even if its shaded... to be able to see again just change your timeline +1 or -1 frame to recalculate or in the tyflow editor top right there is a refresh button ... if u press it tyflow will recalculate so u can see your particles again...
RE: shaded viewport visibility - tycera - 08-18-2022 (08-18-2022, 07:37 AM)Credemon Wrote: while caching if u press ESC tyflow will not show any mesh or "ticks" in the viewport even if its shaded... Maybe that was it. Thanks! |
