tyMesher and vdb flow - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: tyMesher and vdb flow (/thread-3287.html) |
tyMesher and vdb flow - savat - 08-31-2022 Hi guys, more than a year I don't use tyFlow. Is there a reason why tyMesher reads a vdb flow only in tet mode? My workaround actually is to apply an "edit poly" modifier in to flow stack but...tired of workarounds ![]() ps: I use a free version downloaded 2 o 3 weeks ago. RE: tyMesher and vdb flow - tyFlow - 09-01-2022 The tyMesher in the latest build already contains a dropdown where you can select 'ignore particle interface' as the interface option. That will allow you to grab the raw (VDB) meshes from the selected tyFlow object, avoiding needs for workarounds. RE: tyMesher and vdb flow - savat - 09-01-2022 (09-01-2022, 05:05 AM)tyFlow Wrote: The tyMesher in the latest build already contains a dropdown where you can select 'ignore particle interface' as the interface option. That will allow you to grab the raw (VDB) meshes from the selected tyFlow object, avoiding needs for workarounds. oh...thanks a lot. |
