Particles Export Error - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Particles Export Error (/thread-3289.html) |
Particles Export Error - yamen3d - 09-01-2022 I have problem with export particles, with low number of particles, I've turned of Ram cache and Surface cache but did not compete .. 3ds max closed Application Error message. I don't know if this is bug or I've made mistake 3ds max 2020 tyFlow 1.009 Pc memory 128 gr RE: Particles Export Error - tyFlow - 09-01-2022 Can you send the scene please? RE: Particles Export Error - yamen3d - 09-01-2022 (09-01-2022, 03:57 PM)tyFlow Wrote: Can you send the scene please?Thank you I'll send max file but I can't send Phoenix fd Cache its about 60GB https://drive.google.com/file/d/1zXDmVAvkEm5sqz9Z5OhfAhWtfnP_qBNR/view?usp=sharing RE: Particles Export Error - tyFlow - 09-01-2022 Can you also post the minidump from the crash? Instructions for finding it are in the sticky post. RE: Particles Export Error - yamen3d - 09-01-2022 (09-01-2022, 05:14 PM)tyFlow Wrote: Can you also post the minidump from the crash? Instructions for finding it are in the sticky post. https://drive.google.com/file/d/1GTdQq40avipuS11dWxxt2ZOd9rgC_ax-/view?usp=sharing RE: Particles Export Error - yamen3d - 09-01-2022 start: MTf: ©Fn end: MTf: ©Fn start: SimulateParticles start: calcSimValidity end: calcSimValidity start: StartSimulation start: operators end: operators end: StartSimulation start: StepSimulation start: MTf: &clearParticleFlags end: MTf: &clearParticleFlags start: getLastTimestepData start: MTf: &getLastTimestepData end: MTf: &getLastTimestepData end: getLastTimestepData start: operators start: Birth Fluid start: PreStepSimulation end: PreStepSimulation start: update phx object end: update phx object start: birth phx particles start: initDiffuseParticles start: MTf: lambda end: MTf: lambda end: initDiffuseParticles start: extractDensityGrid start: MTf: lambda end: MTf: lambda end: extractDensityGrid start: convertDensityToSDF end: convertDensityToSDF start: computeCurvature end: computeCurvature start: computeGradient end: computeGradient start: analyzeSDF start: MTf: lambda end: MTf: lambda start: removeInteriorSamples end: removeInteriorSamples end: analyzeSDF start: extractSDFData start: MTf: lambda end: MTf: lambda end: extractSDFData start: findDiffuseParticleBirthPoints start: MTf: lambda end: MTf: lambda end: findDiffuseParticleBirthPoints start: generateDiffuseParticles start: MTf: lambda end: MTf: lambda start: MTf: &resetParticles end: MTf: &resetParticles start: MTf: lambda end: MTf: lambda end: generateDiffuseParticles end: birth phx particles end: Birth Fluid start: Fluid Force start: PreStepSimulation end: PreStepSimulation start: updatePhxObject end: updatePhxObject start: MTf: &phxForceParticles RE: Particles Export Error - tyFlow - 09-02-2022 The issue is related to parsing the PhoenixFD cache, but it's hard to tell if it's memory-related or something else. When the crash occurs, is your RAM full? RE: Particles Export Error - yamen3d - 09-02-2022 (09-02-2022, 03:32 AM)tyFlow Wrote: The issue is related to parsing the PhoenixFD cache, but it's hard to tell if it's memory-related or something else.I've tried to use Re Simulation in Phoenix fd to simulate Foam,Splash its worked perfect for all frames but I'll try to open task manager and record screen or watching when tyFlow Export particles RE: Particles Export Error - tyFlow - 09-02-2022 Ohhh you’re doing a foam sim. Yea you’re probably running out of RAM due to the way the Birth Fluid operator caches the surface analysis to speed up calcs for fast setting iterations. Just disable the cache in the Birth Fluid operator. I hope to improve this in the future. |
