tySelect support splines - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: tySelect support splines (/thread-3443.html) |
tySelect support splines - betamax - 01-20-2023 Is it possible to have tySelect support spline/spline elements? Maybe tyselect could autoswitch into a 'spline mode', when added to a spline object? Thanks ![]() RE: tySelect support splines - tyFlow - 02-04-2023 tySelect already supports splines...but only selections of spline knots. RE: tySelect support splines - betamax - 03-09-2023 That's a shame, is it possible for it to support Spline Elements? RE: tySelect support splines - boogiepictures - 11-21-2023 I need the option to select the splines by ID like in Volume Select. So I can build my own modifier stack based on IDsĀ Is it possible to do that? Thank you. RE: tySelect support splines - tyFlow - 11-22-2023 The tySelect spline support is still limited to knots only. |
