birthing objects along a grid? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: birthing objects along a grid? (/thread-3516.html) |
birthing objects along a grid? - tybro - 02-21-2023 I'm sure there is a real simple solution to this but i need to evenly distribute my birthed objects on a plane radiating out from center. What would be the best way to set this up? Thanks RE: birthing objects along a grid? - tyFlow - 02-21-2023 Birth Surface > vertices, on a plane with evenly spaced segments? RE: birthing objects along a grid? - tybro - 02-21-2023 (02-21-2023, 05:39 PM)tyFlow Wrote: Birth Surface > vertices, on a plane with evenly spaced segments? i see that, but how would i birth teapots at those specific spots for instance? RE: birthing objects along a grid? - tyFlow - 02-21-2023 Use a Shape operator and specify a teapot as the reference object. RE: birthing objects along a grid? - tybro - 02-22-2023 sorry for being so dumb here, but now i need them birthing outward from center. I created this initially with birth>shape>position object(using an animated torus to birth them)>rotation>physX shape so they drop in place. but i'd like their placement to be more uniform, which i wasnt able to achieve with fuse or spread. the alternate set up is birth surface>shape - which aligns them perfectly but i lose the animated birth |
