Texture image sequence random time - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: Texture image sequence random time (/thread-3539.html) |
Texture image sequence random time - leepuznowski - 03-01-2023 I have a Tyflow that creates around 7.000 cubes aligned in rows which have a multi-subobject material applied to it. This material has 17 different Vray materials attatched, each with a different image sequence as a texture. My problem is, I can see obvious repeating of textures. To avoid this, I would like to randomly shift the timing of the image sequences for all the 7.000 cubes to avoid the obvious repeating. How can I achieve this? Thanks in advance. RE: Texture image sequence random time - leepuznowski - 03-01-2023 To simplify. I would like to randomize the starting point of the playback of a texture (image sequence) over many particles. RE: Texture image sequence random time - tyFlow - 03-01-2023 This is definitely possible...have you looked at the tyBitmap texmap? You can use it to control individual particles' playback of an image sequence. RE: Texture image sequence random time - leepuznowski - 03-02-2023 (03-01-2023, 04:58 PM)tyFlow Wrote: This is definitely possible...have you looked at the tyBitmap texmap? You can use it to control individual particles' playback of an image sequence. I just started looking into the tyBitmap yesterday but haven't yet figured out how to implement it. My main problem with tyBitmap is, as far as I am aware, it doesn't support Vray GPU. Is this correct? At least, it doesn't work with GPU IPR. |
