freezing particles efficiently - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: freezing particles efficiently (/thread-3552.html) |
freezing particles efficiently - tycera - 03-07-2023 I'd like to create a bunch of particles on frame 0 and just have them frozen there. What options do I have .. 1. to freeze the particles as they are on frame 0 so that tyFlow doesn't have to update? 2. to freeze everything except for example orientation? I know I can use cache, but I couldn't find a way to hold the first frame. RE: freezing particles efficiently - d4rk3lf - 03-07-2023 - You can use Birth Flow in another TyFlow system that will read any frame of your initial TyFlow sim. I used it often when I do heavy PhysX sims, so I fracture them in first Tyflow, then I use Birth Flow, select the first flow, and when I apply PhysX Shape, it doesn't have to fracture particles all over again. Another useful operator is Flow Update, and is used of you want to load animation from first flow. - If you want a simple mesh, you can add mesh operator, disable "render only", and just do a simple snapshoot. RE: freezing particles efficiently - tycera - 03-08-2023 Thanks. I couldn't find a way to disable the first flow. How do I do that? RE: freezing particles efficiently - d4rk3lf - 03-08-2023 You don't disable it, you need it to be active, in order that second flow reads from first. I personally, just hide it with right click - hide selected, or on eye icon on the scene explorer. RE: freezing particles efficiently - tycera - 03-20-2023 Thanks. So it would still be required to be calculated on every step? Is there a way to have it only calculated for example on the first frame only and pass those particles? |
